メインコンテンツにスキップ
LG env2 vx9100 Camera Replacement
必要な工具と部品
  1. LG env2 vx9100 Camera Replacement, Battery: 手順 1、 3の画像 1 LG env2 vx9100 Camera Replacement, Battery: 手順 1、 3の画像 2 LG env2 vx9100 Camera Replacement, Battery: 手順 1、 3の画像 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Camera Replacement, Back Panel: 手順 2、 2の画像 1 LG env2 vx9100 Camera Replacement, Back Panel: 手順 2、 2の画像 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Camera Replacement: 手順 3、 2の画像 1 LG env2 vx9100 Camera Replacement: 手順 3、 2の画像 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Camera Replacement: 手順 4、 2の画像 1 LG env2 vx9100 Camera Replacement: 手順 4、 2の画像 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Camera Replacement, Camera: 手順 5、 2の画像 1 LG env2 vx9100 Camera Replacement, Camera: 手順 5、 2の画像 2
    • Locate the ribbon attached to the lens of the camera.
    • Place the plastic opening tool in between the logic board and ribbon.
    • Lift up the plastic opening to detach the ribbon from the logic board.
  6. LG env2 vx9100 Camera Replacement: 手順 6、 2の画像 1 LG env2 vx9100 Camera Replacement: 手順 6、 2の画像 2
    • Place the plastic opening tool in between the lens and the logic board.
    • Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Take the entire lens and ribbon off of the logic board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Reed Williston
メンバー登録日: 09/26/12
34 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G55
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 461
