はじめに
In this guide you will be removing the back panel to access the motherboard. Once you have reached the motherboard you will remove the camera lens from the motherboard.
必要な工具と部品
Place the phone face down on the table.
Use your fingernail or an opening tool to pull down the tab below the battery.
Lift the battery out.
Locate the five rubber covers on the back panel of the phone.
Use the metal probe to pop out each rubber cover to reveal the screws underneath.
Locate the ribbon attached to the lens of the camera.
Place the plastic opening tool in between the logic board and ribbon.
Lift up the plastic opening to detach the ribbon from the logic board.
ある他の人がこのガイドを完成しました。
