はじめに
Removing the motherboard is for more serious problems or problems having to do with the screens. It can be tricky so be very careful.
ツール
パーツ
パーツは指定されていません。
Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
The battery should easily fall out after the top of the battery has been pulled out.
Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
ある他の人がこのガイドを完成しました。
