はじめに
This guide will help you replace the speaker, ensuring clear audio and no more missed calls. Follow our step-by-step instructions for a confident and cost-effective repair.
Before beginning step one, make sure you have a clean working space and all necessary tools.
必要な工具と部品
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
Using the plastic opening tool, carefully slide the edge of the tool under the press fit cable connections and lift up to disconnect. Do this for all three ribbon cables.
ある他の人がこのガイドを完成しました。
