はじめに
Use this guide to remove the screen on your front panel assembly.
必要な工具と部品
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
終わりに
ある他の人がこのガイドを完成しました。
