メインコンテンツにスキップ
LG X Style Camera Flash Replacement
必要な工具と部品
  1. LG X Style Camera Flash Replacement, Battery: 手順 1、 1の画像 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Camera Flash Replacement: 手順 2、 2の画像 1 LG X Style Camera Flash Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Camera Flash Replacement, Screen: 手順 3、 2の画像 1 LG X Style Camera Flash Replacement, Screen: 手順 3、 2の画像 2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Camera Flash Replacement: 手順 4、 3の画像 1 LG X Style Camera Flash Replacement: 手順 4、 3の画像 2 LG X Style Camera Flash Replacement: 手順 4、 3の画像 3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Camera Flash Replacement, Camera Flash: 手順 5、 2の画像 1 LG X Style Camera Flash Replacement, Camera Flash: 手順 5、 2の画像 2
    • Using a plastic opening tool, lift up display connection until disconnected from the lower right hand of the phone.
    • Carefully lift the metal connection perpendicular to the mother board.
  6. LG X Style Camera Flash Replacement: 手順 6、 2の画像 1 LG X Style Camera Flash Replacement: 手順 6、 2の画像 2
    • Gently lift the camera ribbon cable until the entire front camera housing is removed.
  7. LG X Style Camera Flash Replacement: 手順 7、 3の画像 1 LG X Style Camera Flash Replacement: 手順 7、 3の画像 2 LG X Style Camera Flash Replacement: 手順 7、 3の画像 3
    • Use the opening tool, gently pry up along the edge of the motherboard.
    • Gently pull up and remove the motherboard from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
cecilia morales
メンバー登録日: 04/09/18
361 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 284
