はじめに
In order to replace your battery case you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the battery case for the LG Watch Urbane.
必要な工具と部品
Use the PH000 screwdriver to remove the two highlighted screws to release the battery
ある他の人がこのガイドを完成しました。
