はじめに
Use this guide to remove and clean the dispenser drawer on a general LG washing machine. The dispenser drawer, detergent drawer, soap drawer, or detergent dispenser holds laundry detergent and fabric softener before they rinse into the drum. Over time, detergent residue, fabric softener buildup, mold, and blocked dispenser jets can cause grime to wash into clothes or stop fabric softener from emptying properly. This guide is written for general LG washing machine models; drawer layouts and release tabs may vary slightly.
必要な工具と部品
手順1 Prepare the washer
Have hot, soapy water and a cloth ready for wiping residue and mold.
Wear rubber gloves if detergent residue, mold, or hot water may irritate skin.
手順2 Locate the dispenser drawer
Stand in front of the washer and find the detergent dispenser drawer in the top-left corner.
Pull the drawer straight out gently until it reaches the stop.
手順3 Unlock and remove the drawer
Look at the back of the open drawer for the release button or clip.
Press down the blue release button to unlock the drawer.
Keep the button pressed and pull the drawer straight out of the washer.
手順4 Remove the fabric softener indicator
If the drawer has a fabric softener level indicator, lift it up to remove it.
手順5 Clean the dispenser drawer
Use a brush with hot, soapy water to scrub mold, detergent residue, and residue from the inside of the drawer.
Wipe the outside of the dispenser tray with the soapy cloth.
Clean until the drawer compartments are free of visible buildup.
手順6 Clean the drawer cavity
Inspect the dispenser drawer cavity before reinstalling the drawer.
Use the soapy cloth to wipe inside the cavity and across the jets at the top.
Use the brush to scrub heavy residue or blocked jets.
手順7 Reinsert the dispenser drawer
Align the drawer with the dispenser cavity.
Slide the drawer straight into the washer until it is fully seated.
手順8 Check the drum rubber
Open the washer door and inspect the rubber seal around the inside of the drum.
Use the damp, soapy cloth to clean the rubber folds.
Clear debris from any drainage holes so water can drain properly.
Use the brush to scrub the rubber if it is very grubby.
手順9 Run a hot maintenance cycle
Close the washer door and dispenser drawer.
Select the 90 °C washing program or the Drum Clean option if the washer has one.
Run the cycle with no clothes to flush residue from the system.
Repeat this cleaning whenever the dispenser drawer or drum rubber shows residue, mold, or fabric softener buildup. Repair didn't go as planned? Ask our Answers community for help.
