メインコンテンツにスキップ
LG Voyager Antenna Replacement
必要な工具と部品
  1. LG Voyager Antenna Replacement, Battery: 手順 1、 1の画像 1
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Antenna Replacement: 手順 2、 1の画像 1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Antenna Replacement: 手順 3、 1の画像 1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Antenna Replacement, Antenna: 手順 4、 1の画像 1
    • First remove the battery by pulling the tab away from the device
    • Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
  5. LG Voyager Antenna Replacement: 手順 5、 2の画像 1 LG Voyager Antenna Replacement: 手順 5、 2の画像 2
    • Next remove the 6 #00 Phillips screws holding the back in place
    • screws: 1.43mm head, 3.61mm length
  6. LG Voyager Antenna Replacement: 手順 6、 3の画像 1 LG Voyager Antenna Replacement: 手順 6、 3の画像 2 LG Voyager Antenna Replacement: 手順 6、 3の画像 3
    • Now, slide a plastic opening tool in between the two plastic pieces that form the outside of the back case
    • Gently work the plastic opening tool around the edge of the case to separate the two pieces
    • Once the case has been separated you should be able to see the circuitry inside the phone
  7. LG Voyager Antenna Replacement: 手順 7、 3の画像 1 LG Voyager Antenna Replacement: 手順 7、 3の画像 2 LG Voyager Antenna Replacement: 手順 7、 3の画像 3
    • Remove the #00 Philips screw holding the antenna in place
    • Screw: 4.52mm length, 2.68mm head
    • Once the screw is removed, lift the small case around the antenna off
  8. LG Voyager Antenna Replacement: 手順 8、 2の画像 1 LG Voyager Antenna Replacement: 手順 8、 2の画像 2
    • Now that you have the antenna exposed, you can remove it
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Paul Heckler II
メンバー登録日: 04/12/12
40 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-26, Amido Spring 2012 Cal Poly, Team 17-26, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G26
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 312
