この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Found this in the bottom of a closet and through some troubleshooting decided the charging port was broken.
Couldn't find any instructions here so I'm uploading some.
*Please Ignore the goofy white borders, forgot to consider aspect ratio when taking the pictures*
必要な工具と部品
There is a pry tab you can use your fingernail or a pry tool to remove the rear cover.
Remove the 11 screws on the inside rear cover using your Phillips screw driver.
See photo from "Remove Battery" step for location of screws.
Use your pry tool and carefully work your way around the inside rear cover to undo the snaps and remove it.
Disconnect the 3 cables and two screws before attempting to remove the charging port circuitry.
Beware the adhesive on the back!
2 の人々がこのガイドを完成させました。
