はじめに
The front keypad suffers a lot of wear-and-tear, but can be easily replaced. This guide will show you how to remove the old keypad so that you may install a new one.
必要な工具と部品
Remove the two triangular pads at the top of the two speakers.
These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
もう少しです!
ゴール
