メインコンテンツにスキップ
LG VX8700 LCD Screen Replacement
必要な工具と部品
  1. LG VX8700 LCD Screen Replacement, Battery: 手順 1、 2の画像 1 LG VX8700 LCD Screen Replacement, Battery: 手順 1、 2の画像 2
    • Power the phone off.
    • Slide the back cover off using the release latch with your fingers to expose the battery.
  2. LG VX8700 LCD Screen Replacement: 手順 2、 2の画像 1 LG VX8700 LCD Screen Replacement: 手順 2、 2の画像 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, align the metal pins with those of the phone.
  3. LG VX8700 LCD Screen Replacement, Front Bezel: 手順 3、 1の画像 1
    • Turn your phone around and open the flip phone. The screen is now facing you.
    • Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
    • Remove the two grey screw-covers.
  4. LG VX8700 LCD Screen Replacement: 手順 4、 2の画像 1 LG VX8700 LCD Screen Replacement: 手順 4、 2の画像 2
    • Use the ejection tab at the top to remove the screen.
    • There is a gap between the case and the screen near the ear piece.
    • Insert the plastic opening tool in the gap and pry up the screen.
    • The plastic screen cover is glued onto the phone. It may be difficult to pry off.
  5. LG VX8700 LCD Screen Replacement: 手順 5、 1の画像 1
    • Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
  6. LG VX8700 LCD Screen Replacement: 手順 6、 2の画像 1 LG VX8700 LCD Screen Replacement: 手順 6、 2の画像 2
    • Turn your phone around. The battery side will be facing you.
    • Insert the plastic opening tool into the groove to remove the top cover of the phone.
    • Carefully open the cover.
  7. LG VX8700 LCD Screen Replacement, Ear Piece: 手順 7、 1の画像 1
    • Locate the earpiece, which is the black component at the top with black and red wires.
    • Remove the component. Using a soldering iron, desolder the top ear piece.
  8. LG VX8700 LCD Screen Replacement: 手順 8、 2の画像 1 LG VX8700 LCD Screen Replacement: 手順 8、 2の画像 2
    • Using the plastic opening tool, lift the earpiece to remove it from the phone.
  9. LG VX8700 LCD Screen Replacement, LCD Screen: 手順 9、 1の画像 1
    • Using a soldering iron, desolder the wires connected to the LCD board.
  10. LG VX8700 LCD Screen Replacement: 手順 10、 1の画像 1
    • Using the plastic opening tool, carefully disconnect the ribbon connecting the two pieces.
  11. LG VX8700 LCD Screen Replacement: 手順 11、 1の画像 1
    • Remove the LCD screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Stanley Thomas
メンバー登録日: 01/20/12
41 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G16
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 1,764
