メインコンテンツにスキップ
LG VX8700 Ear Piece Replacement
必要な工具と部品
  1. LG VX8700 Ear Piece Replacement, Battery: 手順 1、 2の画像 1 LG VX8700 Ear Piece Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Ear Piece Replacement: 手順 2、 2の画像 1 LG VX8700 Ear Piece Replacement: 手順 2、 2の画像 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Ear Piece Replacement, Front Bezel: 手順 3、 1の画像 1
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  4. LG VX8700 Ear Piece Replacement: 手順 4、 2の画像 1 LG VX8700 Ear Piece Replacement: 手順 4、 2の画像 2
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  5. LG VX8700 Ear Piece Replacement: 手順 5、 1の画像 1
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  6. LG VX8700 Ear Piece Replacement: 手順 6、 2の画像 1 LG VX8700 Ear Piece Replacement: 手順 6、 2の画像 2
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
  7. LG VX8700 Ear Piece Replacement, Ear Piece: 手順 7、 1の画像 1
    • Desolder the top ear piece using a soldering iron to remove the component
    • The ear piece is the black component that is located at the top with black and red wires
  8. LG VX8700 Ear Piece Replacement: 手順 8、 2の画像 1 LG VX8700 Ear Piece Replacement: 手順 8、 2の画像 2
    • Remove the ear piece from the phone by lifting it using a plastic opening tool.
終わりに
作成者
5人の作成者と共同で作成されました。
Stanley Thomas
メンバー登録日: 01/20/12
41 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G16
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 988
