メインコンテンツにスキップ
LG VX8550 Screen Replacement
必要な工具と部品
  1. LG VX8550 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Slide the battery release up.
  2. LG VX8550 Screen Replacement: 手順 2、 1の画像 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Screen Replacement, Case: 手順 3、 1の画像 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Screen Replacement: 手順 4、 1の画像 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Screen Replacement: 手順 5、 1の画像 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Screen Replacement: 手順 6、 1の画像 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Screen Replacement: 手順 7、 1の画像 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Screen Replacement, Motherboard: 手順 8、 1の画像 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Screen Replacement: 手順 9、 1の画像 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Screen Replacement: 手順 10、 1の画像 1
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Screen Replacement, Keypad Housing: 手順 11、 1の画像 1
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Screen Replacement: 手順 12、 1の画像 1
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Screen Replacement: 手順 13、 1の画像 1
    • Lift the keypad housing away from the slider.
  14. LG VX8550 Screen Replacement, Front Case: 手順 14、 1の画像 1
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. LG VX8550 Screen Replacement: 手順 15、 1の画像 1
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. LG VX8550 Screen Replacement: 手順 16、 1の画像 1
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. LG VX8550 Screen Replacement: 手順 17、 1の画像 1
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. LG VX8550 Screen Replacement: 手順 18、 1の画像 1
    • Slide ribbon cable through the slider mechanism.
  19. LG VX8550 Screen Replacement: 手順 19、 1の画像 1
    • Separate the two halves.
  20. LG VX8550 Screen Replacement, Screen: 手順 20、 1の画像 1
    • With the spudger, lift up under the connector to unplug it from the circuit board.
  21. LG VX8550 Screen Replacement: 手順 21、 1の画像 1
    • Lift and remove the blue tape from screen connector.
  22. LG VX8550 Screen Replacement: 手順 22、 1の画像 1
    • Lift the top edge of the screen using a pin to pry under the corner.
  23. LG VX8550 Screen Replacement: 手順 23、 1の画像 1
    • Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
    • It is helpful to gently wiggle the ribbon cable from side to side.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nathan Jones
メンバー登録日: 04/10/10
89 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010人のメンバー
CPSU-FORTE-S10S34G55
5 メンバー
20のガイドは作成済み
コメント 1 件
What’s the process if I just need to replace the flex cable not the whole screen?
Roll Sumthin - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 3,941
