はじめに
If your motherboard has failed or is beginning to fail and you need to replace it, follow this guide for the LG VX7000.
Prior to beginning the guide, make sure to turn off the phone and disconnect or remove the battery and make sure that it is not connected to a charging cable.
必要な工具と部品
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
Use the Phillips #00 and remove the four screws on the lower backside of the phone.
Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
