メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Replace damaged keypad.
パーツ
パーツは指定されていません。
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Locate four screws underneath of the battery.
    • Locate four screws underneath of the battery.
    • Remove screws by turning counter clockwise with screwdriver until they pop out.
  5. Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Note: There will be a significant amount of resistance.
  6. Lift up logic board without completely removing from phone.
    • Lift up logic board without completely removing from phone.
    • Remove entire keypad from beneath the logic board.
  7. Insert replacement keypad with buttons aligned in proper holes.
    • Insert replacement keypad with buttons aligned in proper holes.
終わりに
Nichole Shaw
メンバー登録日: 2010年04月13日
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S18G75
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,001
