メインコンテンツにスキップ
はじめに
Replace a cracked internal LCD display.
Note: to replace the internal display, you must replace the entire face plate, not just the plastic screen.
パーツ
パーツは指定されていません。
  1. Using Tweezers, remove 4 rubber screw covers.
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. Unsnap gold plate from the secondary logic board.
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. Twist upper half of face plate in order to release it from the hinge.
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. Align new face plate in correct orientation in order to install.
    • Align new face plate in correct orientation in order to install.
終わりに
Nichole Shaw
メンバー登録日: 2010年04月13日
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S18G75
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,168
