メインコンテンツにスキップ
LG VX7000 External LCD Display Replacement
必要な工具と部品
  1. LG VX7000 External LCD Display Replacement, External LCD Display: 手順 1、 1の画像 1
    • Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
    • NOTE: There will be a total of four rubber screw covers removed.
    • Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
    • NOTE: The screws can not be completely removed from their holes.
  2. LG VX7000 External LCD Display Replacement: 手順 2、 1の画像 1
    • Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
    • NOTE: There will be a significant amount of resistance when separating the faceplate from the phone.
    • Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
終わりに
作成者
5人の作成者と共同で作成されました。
Nichole Shaw
メンバー登録日: 04/13/10
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S18G75
4 メンバー
14のガイドは作成済み
コメント 1 件
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
chayp62 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,688
