はじめに
Phone won't charge, and the charger is functional? Replace your phone's charging adapter.
NOTE: Charging adapter is attached to the logic board, so replacement requires replacing the logic board.
必要な工具と部品
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
Use the Phillips #00 and remove the four screws on the lower backside of the phone.
Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
もう少しです!
終わりに
