メインコンテンツにスキップ
LG VX6100 Logic Board Replacement
必要な工具と部品
  1. LG VX6100 Logic Board Replacement, Back Cover: 手順 1、 1の画像 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Logic Board Replacement: 手順 2、 1の画像 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Logic Board Replacement: 手順 3、 1の画像 1
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Logic Board Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Logic Board Replacement: 手順 5、 2の画像 1 LG VX6100 Logic Board Replacement: 手順 5、 2の画像 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Logic Board Replacement, Logic Board: 手順 6、 2の画像 1 LG VX6100 Logic Board Replacement, Logic Board: 手順 6、 2の画像 2
    • Locate the solder joint on the top portion of the logic board. It will appear as a shiny silver bead of metal.
    • Place a piece of solder wick on top of the solder.
    • To desolder the connection, very carefully place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • The soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat above steps if any solder remains.
  7. LG VX6100 Logic Board Replacement: 手順 7、 2の画像 1 LG VX6100 Logic Board Replacement: 手順 7、 2の画像 2
    • One the solder is gone, pry the copper piece off the logic board.
    • You can then remove the logic board from the case.
終わりに
作成者
6人の作成者と共同で作成されました。
Eric Funsten
メンバー登録日: 04/17/12
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S12G39
3 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 875
