メインコンテンツにスキップ
LG VX6100 Battery Replacement
必要な工具と部品
  1. LG VX6100 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
  2. LG VX6100 Battery Replacement: 手順 3、 1の画像 1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
終わりに
If after completing the replacement, the device still does not operate properly, further troubleshooting must be done to find and solve the issue.
作成者
6人の作成者と共同で作成されました。
Eric Funsten
メンバー登録日: 04/17/12
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S12G39
3 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 825
