メインコンテンツにスキップ
LG VX6000 Screen Replacement
必要な工具と部品
  1. LG VX6000 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Locate the dark gray tab on the back of the phone.
    • Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Screen Replacement: 手順 2、 1の画像 1
    • Lift and rotate the battery away from the bottom edge.
    • Remove the battery.
  3. LG VX6000 Screen Replacement, Body: 手順 3、 1の画像 1
    この手順で使用する道具:
    • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Screen Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
    • Place the screws on an uncluttered surface or in a small container.
  5. LG VX6000 Screen Replacement: 手順 5、 1の画像 1
    • Carefully remove the back of the phone with your fingernails or tweezers.
    • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
    • The red and blue wires must be plugged in to reassemble.
  6. LG VX6000 Screen Replacement, Logic Board: 手順 6、 1の画像 1
    • Carefully peel away the adhesive tab.
    • The tab should not be completely separated from the phone.
  7. LG VX6000 Screen Replacement: 手順 7、 2の画像 1 LG VX6000 Screen Replacement: 手順 7、 2の画像 2
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Carefully pry the connector away from the motherboard to remove it from the phone.
    • Do not pull forcefully
  8. LG VX6000 Screen Replacement: 手順 8、 1の画像 1
    • Gently lift the corner of the motherboard away from the casing.
  9. LG VX6000 Screen Replacement, Screen: 手順 9、 3の画像 1 LG VX6000 Screen Replacement, Screen: 手順 9、 3の画像 2 LG VX6000 Screen Replacement, Screen: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Using a paper clip or tweezers, pop out the screen by pressing the plastic tab in the top-left corner of the phone's bottom casing as indicated in the photo.
    • Be careful not to lose the tab that pops out. It is a small and clear piece of plastic.
    • The tab is fragile, handle with care.
  10. LG VX6000 Screen Replacement: 手順 10、 3の画像 1 LG VX6000 Screen Replacement: 手順 10、 3の画像 2 LG VX6000 Screen Replacement: 手順 10、 3の画像 3
    • As shown in the photos, pull the orange strip through a thin opening at the top of the phone. Once this is done, the top and bottom halves can be separated.
  11. LG VX6000 Screen Replacement: 手順 11、 1の画像 1
    • Set the bottom half of the phone aside.
    • Using tweezers, pull off the small rubber cushions located towards the four corners of the screen.
  12. LG VX6000 Screen Replacement: 手順 12、 1の画像 1
    • With a Phillips tip screwdriver, unscrew the four newly exposed screws.
    • Keep screws from the different steps in different locations so as to not mix them up.
  13. LG VX6000 Screen Replacement: 手順 13、 3の画像 1 LG VX6000 Screen Replacement: 手順 13、 3の画像 2 LG VX6000 Screen Replacement: 手順 13、 3の画像 3
    • Carefully open the casing using the iFixit plastic tool by prying each side a little bit at a time. Rotate and open until all the inside clips pop open and the casing opens up.
  14. LG VX6000 Screen Replacement: 手順 14、 2の画像 1 LG VX6000 Screen Replacement: 手順 14、 2の画像 2
    • After you pry open the casing, you will be left with the screen and circuit board in the top face plate.
    • Gently pull the corner of screen and circuit board up and out of casing to remove screen from the top face plate.
    • Do not try to completely separate the circuit board from the casing. There are still wires connecting the two.
  15. LG VX6000 Screen Replacement: 手順 15、 1の画像 1
    • Rotate the screen and the connected white frame away from the logic board.
    • Carefully peel the adhesive tape that connects the screen and logic board off. The screen can now be removed and replaced with a new screen unit.
終わりに
作成者
17人の作成者と共同で作成されました。
Adam Altman
メンバー登録日: 01/14/10
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S4G11
5 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,869
