メインコンテンツにスキップ
LG VX6000 Keyboard Replacement
必要な工具と部品
  1. LG VX6000 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the battery by lifting up and rotating the battery away from the bottom edge.
  3. LG VX6000 Keyboard Replacement, Body: 手順 3、 1の画像 1
    • Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Keyboard Replacement: 手順 4、 1の画像 1
    • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Remove screws and carefully place on an uncluttered surface or in a small container.
  5. LG VX6000 Keyboard Replacement: 手順 5、 1の画像 1
    • Carefully remove the back of the phone gently using your fingernails or tweezers.
    • There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
    • To reattach the back, you must plug these wires back in.
  6. LG VX6000 Keyboard Replacement, Logic Board: 手順 6、 1の画像 1
    • Carefully peel off the adhesive tab as shown in the photo
    • The tab should not fully separate from the phone.
  7. LG VX6000 Keyboard Replacement: 手順 7、 2の画像 1 LG VX6000 Keyboard Replacement: 手順 7、 2の画像 2
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
    • Do not pull too hard on the connector.
  8. LG VX6000 Keyboard Replacement: 手順 8、 1の画像 1
    • Gently lift a corner of the motherboard away from the casing to remove.
  9. LG VX6000 Keyboard Replacement, Keyboard: 手順 9、 1の画像 1
    • Peel the white keypad off the casing.
終わりに
作成者
9人の作成者と共同で作成されました。
Adam Altman
メンバー登録日: 01/14/10
1 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S4G11
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,753
