はじめに
This guide is for dismantling the body of the LG VX6000, a step that is required for many other repairs
パーツ
パーツは必要ありません。
  1. Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
    • Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
  2. Remove the battery by lifting up and rotating the battery away from the bottom edge.
    • Remove the battery by lifting up and rotating the battery away from the bottom edge.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Pull out the two rubber cushions located on the top of the phone using tweezers.
    • Only remove the two cushions that are circled!
  5. Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
    • Remove screws and carefully place on an uncluttered surface or in a small container.
  6. Carefully remove the back of the phone gently using your fingernails or tweezers.
    • Carefully remove the back of the phone gently using your fingernails or tweezers.
    • There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
    • To reattach the back, you must plug these wires back in.
ゴール
Barrett Wallace
メンバー登録日: 2010年01月18日
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S4G11
5 メンバー
10のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,022
