メインコンテンツにスキップ
LG VX5600 Plastic Screen Protector Replacement
必要な工具と部品
  1. LG VX5600 Plastic Screen Protector Replacement, Battery: 手順 1、 2の画像 1 LG VX5600 Plastic Screen Protector Replacement, Battery: 手順 1、 2の画像 2
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
  2. LG VX5600 Plastic Screen Protector Replacement: 手順 2、 2の画像 1 LG VX5600 Plastic Screen Protector Replacement: 手順 2、 2の画像 2
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
  3. LG VX5600 Plastic Screen Protector Replacement, Plastic Screen Protector: 手順 3、 1の画像 1
    • Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
  4. LG VX5600 Plastic Screen Protector Replacement: 手順 4、 1の画像 1
    • Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
    • Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
    • Some of the pictures show the bottom of the phone disassembled. It is unneccessary to disassemble the bottom of the phone for this guide.
  5. LG VX5600 Plastic Screen Protector Replacement: 手順 5、 2の画像 1 LG VX5600 Plastic Screen Protector Replacement: 手順 5、 2の画像 2
    • Hold the opened phone upright.
    • Use the spudger to pry around the edges of the phone and detach the tabs.
    • Make sure all the tabs around the grey cover are detached. They are located on the top and on both sides of the screen.
  6. LG VX5600 Plastic Screen Protector Replacement: 手順 6、 1の画像 1
    • Use your finger to lift up the grey plastic cover.
    • Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
    • The plastic screen protector is adhered with glue to the back of the phone, so a little force is required to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Irena Tran
メンバー登録日: 06/04/13
435 ポイント
4のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013 University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013人のメンバー
LOUISVILLE-CHAMBERLAIN-S13S1G5
2 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 422
