はじめに
Most of the bottom portion of the phone will need to be removed to install a new motherboard.
必要な工具と部品
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Grasp the edges of the phone with one hand.
Unscrew the six 5.0-mm Phillips #000 screws located around each side of the back panel of the phone.
もう少しです!
終わりに
