メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG VX5600 Motherboard Replacement
必要な工具と部品
  1. LG VX5600 Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG VX5600 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
    • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
  2. LG VX5600 Motherboard Replacement: 手順 2、 2の画像 1 LG VX5600 Motherboard Replacement: 手順 2、 2の画像 2
    • Insert your finger into the small indentation above the battery.
    • Push down on the battery and pull it away from the phone; it will pop out.
  3. LG VX5600 Motherboard Replacement, Motherboard: 手順 3、 2の画像 1 LG VX5600 Motherboard Replacement, Motherboard: 手順 3、 2の画像 2
    • Grasp the edges of the phone with one hand.
    • Unscrew the six 5.0-mm Phillips #000 screws located around each side of the back panel of the phone.
    • The screws are tight, so you will have to use a little force when unscrewing them.
  4. LG VX5600 Motherboard Replacement: 手順 4、 1の画像 1
    • Insert the spudger into the tab at the top of the back panel and push to release the panel.
    • The back panel will then lift away from the rest of the phone.
  5. LG VX5600 Motherboard Replacement: 手順 5、 2の画像 1 LG VX5600 Motherboard Replacement: 手順 5、 2の画像 2
    • Flip the phone open with the back side still facing you.
    • Grasping the phone from underneath, use your fingers to push up on the keypad until the motherboard can be easily lifted up from the plastic outer casing of the phone.
    • When you do this the plastic camera button will pop out. It is not directly attached to anything. Make sure to save it for reassembly because it must be placed back on its tab at the side with the camera icon facing right side up to work correctly.
  6. LG VX5600 Motherboard Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • With a pair of tweezers, pull the gold flex cable up disconnecting the motherboard.
  7. LG VX5600 Motherboard Replacement: 手順 7、 1の画像 1
    • Use your fingers to lift the motherboard up and away from the phone.
終わりに
作成者
3人の作成者と共同で作成されました。
Jessica Bradley
メンバー登録日: 06/04/13
279 ポイント
2のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013 University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013人のメンバー
LOUISVILLE-CHAMBERLAIN-S13S1G5
2 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 1,437
