メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Often times the key pad could break or become worn. This repair guide will show you how to replace the the keypad of the LG VX5400.
パーツ
パーツは指定されていません。
  1. Turn off the cell phone and turn it over on its back side
    • Turn off the cell phone and turn it over on its back side
  2. Hold the phone case in your palm and slide the back cover towards yourself using your thumb
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it.
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
    • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
  5. Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
    • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
  6. Gently split open the front and back of the bottom casing of the phone with fingers.
    • Gently split open the front and back of the bottom casing of the phone with fingers.
  7. Carefully pull the key pad from the phone through the opening.
    • Carefully pull the key pad from the phone through the opening.
  8. See here for parts that have been removed.
    • See here for parts that have been removed.
終わりに
Vanessa Panchal
メンバー登録日: 2010年04月22日
1 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 26-26, Regan Spring 2010 Cal Poly, Team 26-26, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S26G26
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,270
