メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Remove the rubber stoppers from the four corners of the front screen.
    • Remove the rubber stoppers from the four corners of the front screen.
  2. Using the Phillips screwdriver, carefully remove all four screws.
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. To pry open the face plate, place the iFixit Opener tool in the crease of the phone. To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. Carefully lift off the black frame around the LCD screen and set it aside. Carefully lift off the black frame around the LCD screen and set it aside.
    • Carefully lift off the black frame around the LCD screen and set it aside.
  5. Lift the speaker out by using tweezers.
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  6. Using tweezers, carefully disconnect the orange ribbon from the computer chip.
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  7. Remove the LCD screen and replace with a new one.
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
終わりに
Ashley
メンバー登録日: 2013年02月12日
9 ポイント
3のガイドは作成済み
チーム
Ohio State, Team 1-1, Buehl Spring 2013 Ohio State, Team 1-1, Buehl Spring 2013人のメンバー
OSU-BUEHL-S13S1G1
3 メンバー
4のガイドは作成済み
コメント1件
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 426
