メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Repairing the logic board.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
  3. Remove the rubber grommet using a Spudger.
    • Remove the rubber grommet using a Spudger.
  4. Be sure not to lose the screws. They are small!
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  6. When removing back cover, be careful not to break the speaker wires. Using an iPod Opening Tool, carefully pry off the back cover. Using Tweezers, gently pull speaker wires out.
    • When removing back cover, be careful not to break the speaker wires.
    • Using an iPod Opening Tool, carefully pry off the back cover.
    • Using Tweezers, gently pull speaker wires out.
  7. Separate the two halves.
    • Separate the two halves.
  8. Carefully pry and lift up on the logic board using an iPod Opening Tool. Carefully pry and lift up on the logic board using an iPod Opening Tool. Carefully pry and lift up on the logic board using an iPod Opening Tool.
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  9. Carefully flip the logic board up and out of the way.
    • Carefully flip the logic board up and out of the way.
  10. Use an iPod Opening Tool to lift up on the keypad and pull it out. Use an iPod Opening Tool to lift up on the keypad and pull it out. Use an iPod Opening Tool to lift up on the keypad and pull it out.
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  11. DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • De-solder solder joint on front using Soldering Iron.
  12. De-solder solder joint on the back using Soldering Iron.
    • De-solder solder joint on the back using Soldering Iron.
  13. Carefully detach ribbon cable and remove logic board. Carefully detach ribbon cable and remove logic board. Carefully detach ribbon cable and remove logic board.
    • Carefully detach ribbon cable and remove logic board.
終わりに
David Foster
メンバー登録日: 2010年04月11日
1 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G88
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,476
