メインコンテンツにスキップ
LG VX4500 keyboard replacement duplicate
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. LG VX4500 keyboard replacement duplicate, Battery: 手順 1、 1の画像 1
    • Before removing the battery, ensure that the phone is turned off.
    • To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
  2. LG VX4500 keyboard replacement duplicate: 手順 2、 1の画像 1
    • Pull back on the white release tab and lift up the the entire battery.
  3. LG VX4500 keyboard replacement duplicate: 手順 3、 1の画像 1
    • The back panel should now be fully accessible.
  4. LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: 手順 4、 2の画像 1 LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: 手順 4、 2の画像 2
    • Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
    • With a Phillips head screwdriver, remove all 4 screws from their ports.
    • Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
    • The fifth screw will be more difficult to get out because the plastic port has much higher sides.
  5. LG VX4500 keyboard replacement duplicate: 手順 5、 3の画像 1 LG VX4500 keyboard replacement duplicate: 手順 5、 3の画像 2 LG VX4500 keyboard replacement duplicate: 手順 5、 3の画像 3
    • Run a plastic opening tool along the seam to seperate the keyboard cover and the back panel
    • Remove the back panel, now the logic board, keyboard and microphone are exposed.
  6. LG VX4500 keyboard replacement duplicate, Logic Board: 手順 6、 2の画像 1 LG VX4500 keyboard replacement duplicate, Logic Board: 手順 6、 2の画像 2
    • With your fingers, gently lift up the gold connector until it is completely disconnected.
  7. LG VX4500 keyboard replacement duplicate, Keyboard: 手順 7、 1の画像 1
    • Move the logic board out of the way to reveal the keyboard underneath.
  8. LG VX4500 keyboard replacement duplicate: 手順 8、 2の画像 1 LG VX4500 keyboard replacement duplicate: 手順 8、 2の画像 2
    • Pop the keyboard out using a your finger until the entire keyboard is out.
終わりに
作成者
8人の作成者と共同で作成されました。
iDeleted
メンバー登録日: 07/07/10
2,101 ポイント
39のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 318
