はじめに
Exposing the logic board, keyboard and microphone for replacement.
必要な工具と部品
To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
With a Phillips head screwdriver, remove all 4 screws from their ports.
Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
The fifth screw will be more difficult to get out because the plastic port has much higher sides.
もう少しです!
終わりに
