1. Push the light gray rectangle in the top-center up. While pushing up grab the sides of the battery and pull out. While pushing up grab the sides of the battery and pull out.
    • Push the light gray rectangle in the top-center up.
    • While pushing up grab the sides of the battery and pull out.
  2. Unscrew the antenna by grasping the base and twisting counterclockwise.
    • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside. The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
    • The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
  5. Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone. The bit size is engraved on the base of the bit head.
    • Using a Torx screwdriver with a T6-sized bit, unscrew the four screws on the back of the phone.
    • The bit size is engraved on the base of the bit head.
  6. With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone. Gently pull the two pieces apart to separate. Apply enough force to separate the pieces without cracking the back cover.
    • With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
    • Gently pull the two pieces apart to separate.
    • Apply enough force to separate the pieces without cracking the back cover.
  7. Lift the computer chip to gain access to the keypad and side buttons beneath. CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
    • Lift the computer chip to gain access to the keypad and side buttons beneath.
    • CAUTION: The computer chip is attached with a thin ribbon wire at upper right corner of case. DO NOT BREAK THE RIBBON WIRE.
まとめ
<b>To reassemble your device, follow these instructions in reverse order.</b>
Nico Chiarito
メンバー登録日: 2010年01月21日
22 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 8-47, Regan Winter 2010 Cal Poly, Team 8-47, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G47
5 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,440
