この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
How to remove the clear plastic screen cover.
必要な工具と部品
Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
Pull back panel toward bottom of phone.
Remove the five screws from the back panel, under the battery.
There is a hidden screw under the rubber pad next to the antenna. To remove this pad use a screwdriver to pry out rubber.
Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
Don't be afraid to damage anything, the panel requires a bit of force to detach.
After removing the two halves of the phone, put the logic board, screen, and lower half of the phone aside.
ある他の人がこのガイドを完成しました。
コメント 1 件
This was helpful in a LarGe way! I recently managed to tear the screen off of my wife's phone- you know, like a saucer separation from the next generation! Despite the ribbon being no longer unified I thought I might still have a chance to fix it so that the contact list could still be seen and recorded elsewhere. So I bought an identical model for $6 on EBay and swapped the motherboards. Now this flip phone can be seen with the contact list intact and thanks to this posting we are all 'flipping' happy! Thank you for putting this ancient device up for dissection!!! Drew
