はじめに
If your device isn’t properly taking photos or showing images, the camera may be the underlying issue. Use this guide to replace the front-facing camera in your phone.
必要なもの
Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
Allow to sit for 1-2 minutes to heat up the adhesive.
Gently push down on the small black tab with a Spudger to release the protective board.
Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
Insert Opening Picks if needed to keep the battery elevated.
