メインコンテンツにスキップ
LG V30 Plus Battery Replacement
必要な工具と部品
  1. LG V30 Plus Battery Replacement, Rear Glass: 手順 1、 1の画像 1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Battery Replacement: 手順 2、 2の画像 1 LG V30 Plus Battery Replacement: 手順 2、 2の画像 2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Battery Replacement: 手順 3、 1の画像 1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Battery Replacement, Motherboard: 手順 4、 2の画像 1 LG V30 Plus Battery Replacement, Motherboard: 手順 4、 2の画像 2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Battery Replacement: 手順 5、 3の画像 1 LG V30 Plus Battery Replacement: 手順 5、 3の画像 2 LG V30 Plus Battery Replacement: 手順 5、 3の画像 3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Battery Replacement: 手順 6、 2の画像 1 LG V30 Plus Battery Replacement: 手順 6、 2の画像 2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Battery Replacement: 手順 7、 2の画像 1 LG V30 Plus Battery Replacement: 手順 7、 2の画像 2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Battery Replacement: 手順 8、 1の画像 1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Battery Replacement, Battery: 手順 9、 3の画像 1 LG V30 Plus Battery Replacement, Battery: 手順 9、 3の画像 2 LG V30 Plus Battery Replacement, Battery: 手順 9、 3の画像 3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Samuel Jahnke
メンバー登録日: 04/22/19
279 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S1G3
4 メンバー
10のガイドは作成済み
コメント 1 件
I did this and now my phone’s touch screen is unresponsive. The power button and volume buttons work and the phone turns on, but I cannot unlock my phone due to the touch screen not responding
Julian Marley - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 29
今までの合計 1,925
