はじめに
Use this guide to replace your display in the LG V20.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
You will need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
Remove the back cover.
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use the flat end of a spudger to disconnect the front camera flex cable.
Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
The second rear camera will come out with the motherboard since it is connected on the other side.
You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
Use a pair of tweezers to gently peel off the cable of the secondary screen at the top of your phone.
Use an iOpener to loosen the adhesive on all sides of the display.
Lay overlapping strips of clear packing tape over the phone's display until the whole face is covered.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display and touchscreen cable through the frame. Align the screen and press it into place.
19 の人々がこのガイドを完成させました。
3 件のコメント
Need help: My screen came out so I took the phone apart and re-glued the screen with some 1mm 3M tape. Now I reassembled it and it vibrates on boot and I can see the backlight go on because a corner of the screen is broken off… Also WhatsApp Web works. So the phone is definitely working, but the display isnt showing anything… I re-checked the main screen connector at the bottom and it is properly plugged… what can I do?
Your replacement screen might be bad, or your display cable broke in which case you would need a new motherboard.
Hello,
The secondary screen cable was cut off during the disassembly. Is there any way to fix it or would it be necessary to buy a whole new screen for this purpose?
Thanks.
temp trend - 返信
