メインコンテンツにスキップ
LG Ultimate 2 Digitizer Replacement
必要な工具と部品
  1. LG Ultimate 2 Digitizer Replacement, Battery: 手順 1、 1の画像 1
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: 手順 2、 1の画像 1
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: 手順 3、 1の画像 1
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: 手順 4、 2の画像 1 LG Ultimate 2 Digitizer Replacement, Digitizer: 手順 4、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: 手順 5、 2の画像 1 LG Ultimate 2 Digitizer Replacement: 手順 5、 2の画像 2
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: 手順 7、 1の画像 1
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: 手順 8、 1の画像 1
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: 手順 9、 1の画像 1
    • Pry the screen off after all pieces have been loosened from the adhesive.
終わりに
作成者
3人の作成者と共同で作成されました。
Devin Isenhower
メンバー登録日: 03/21/18
329 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S5-G2, Baechle Spring 2018 IUPUI, Team S5-G2, Baechle Spring 2018人のメンバー
IUPUI-BAECHLE-S18S5G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 387
