メインコンテンツにスキップ
LG UD501KOJ5 Dehumidifier Sensor Replacement
必要な工具と部品
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: 手順 1、 2の画像 1 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: 手順 1、 2の画像 2
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 2、 2の画像 1 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 2、 2の画像 2
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 3、 3の画像 1 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 3、 3の画像 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 3、 3の画像 3
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 4、 3の画像 1 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 4、 3の画像 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 4、 3の画像 3
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 5、 3の画像 1 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 5、 3の画像 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 5、 3の画像 3
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 6、 2の画像 1 LG UD501KOJ5 Dehumidifier Sensor Replacement: 手順 6、 2の画像 2
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
終わりに
作成者
2人の作成者と共同で作成されました。
Gabrielle Campbell
メンバー登録日: 05/12/21
133 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G3, O'Regan Summer 2021 York University, Team S1-G3, O'Regan Summer 2021人のメンバー
YORK-O'REGAN-SU21S1G3
1 メンバー
1のガイドは作成済み
1件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 42
今までの合計 2,867
