はじめに
This guide will show you how to replace the headphone jack in your LG Tribute 5, model LS675. When you insert your headphones into your device and are unable to hear anything or you audio is distorted, replacing the headphone jack may fix this issue.
必要な工具と部品
Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
ある他の人がこのガイドを完成しました。
