メインコンテンツにスキップ
LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement
必要な工具と部品
  1. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove hidden screw.: 手順 1、 3の画像 1 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove hidden screw.: 手順 1、 3の画像 2 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove hidden screw.: 手順 1、 3の画像 3
    この手順で使用する道具:
    購入する
    • First, see which side speaker needs to be replaced.
    • Locate the hidden screw as shown in the picture and remove the rubber piece with tweezers.
    • Remove the screw using a Philips #00 screwdriver.
  2. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Disassemble the headset.: 手順 2、 3の画像 1 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Disassemble the headset.: 手順 2、 3の画像 2 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Disassemble the headset.: 手順 2、 3の画像 3
    • Using a guitar pick or any opening tool, open the frame of the headset.
  3. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove motherboard screw.: 手順 3、 1の画像 1
    • Using a Philips #00 screwdriver remove the screw holding the motherboard in place.
  4. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Move speaker to uncover hidden screw.: 手順 4、 3の画像 1 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Move speaker to uncover hidden screw.: 手順 4、 3の画像 2 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Move speaker to uncover hidden screw.: 手順 4、 3の画像 3
    • Slightly push back on the speaker back housing so the speaker can be pushed out as seen in the pictures.
  5. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker hidden screw.: 手順 5、 2の画像 1 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker hidden screw.: 手順 5、 2の画像 2
    • Once the speaker is out of the way, the hidden screw can be removed using a Philips #00 screwdriver.
  6. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker and motherboard.: 手順 6、 3の画像 1 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker and motherboard.: 手順 6、 3の画像 2 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Remove speaker and motherboard.: 手順 6、 3の画像 3
    • Using a pry/opening tool, slightly lift the speaker and motherboard out of place.
  7. LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Desolder the speaker.: 手順 7、 2の画像 1 LG Tone Ultra HBS-810 Speaker (Right or Left) Replacement, Desolder the speaker.: 手順 7、 2の画像 2
    • Use a soldering iron to desolder the speaker from the motherboard.
終わりに
14 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Faizan Naveed
メンバー登録日: 04/12/17
3,294 ポイント
8のガイドは作成済み
チーム
Mobile Device Repair Factory Mobile Device Repair Factory人のメンバー
Business
1 メンバー
16のガイドは作成済み
8 件のコメント
Thanks for such a thorough guide! Would you happen to know where I could find replacement parts without buying whole units on ebay?
Jordan Heilman - 返信
Your welcome! Not sure where you can buy just replacement parts at the moment. Best bet would be to buy a unit for parts on ebay or amazon.
Faizan Naveed -
I can't hear noise from my left earbud of my lg tone ultra plz tell me how can i fix this problem.few months ago my headphone were working well but after they got in the hands of my nephew accidentally first the sound become disbalance like right earbud can be louder than left one,but after time passes the sound in the left earbud comes to zero and now there is no sound coming out of left earbud ….I can't buy new headphone i would like to repaire it ….!!!
Ali Anwar - 返信
Soak the earbuds in rubbing, isopropyl, or ethanol at 50-70% concentration for an hour. Let it dry out for an hour. The solution will remove salt and other residue from sweat, which causes one side to lose sound over time.
Tung Nguyen - 返信
Still no info on replacement parts?
rezinkillz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 38
今までの合計 16,290
