メインコンテンツにスキップ
LG Thrill 4G Motherboard Replacement
必要な工具と部品
  1. LG Thrill 4G Motherboard Replacement, Back Cover Removal: 手順 1、 2の画像 1 LG Thrill 4G Motherboard Replacement, Back Cover Removal: 手順 1、 2の画像 2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Motherboard Replacement, Battery Removal: 手順 2、 2の画像 1 LG Thrill 4G Motherboard Replacement, Battery Removal: 手順 2、 2の画像 2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Motherboard Replacement, Screw Removal: 手順 3、 1の画像 1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Motherboard Replacement, Speaker Removal: 手順 4、 2の画像 1 LG Thrill 4G Motherboard Replacement, Speaker Removal: 手順 4、 2の画像 2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Motherboard Replacement, Buttons: 手順 5、 1の画像 1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Motherboard Replacement: 手順 6、 3の画像 1 LG Thrill 4G Motherboard Replacement: 手順 6、 3の画像 2 LG Thrill 4G Motherboard Replacement: 手順 6、 3の画像 3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 手順 8、 3の画像 1 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 手順 8、 3の画像 2 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 手順 8、 3の画像 3
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 手順 9、 3の画像 1 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 手順 9、 3の画像 2 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 手順 9、 3の画像 3
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
  10. LG Thrill 4G Motherboard Replacement, Motherboard: 手順 10、 2の画像 1 LG Thrill 4G Motherboard Replacement, Motherboard: 手順 10、 2の画像 2
    • Use a plastic opening tool or spudger to gently disconnect the ribbon cables connected to the motherboard.
    • Disconnect the antenna cable from the bottom right corner of the motherboard.
  11. LG Thrill 4G Motherboard Replacement: 手順 11、 2の画像 1 LG Thrill 4G Motherboard Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a spudger or pair of tweezers to grab the top left corner of the motherboard and gently lift it out, taking care to not damage any of the ribbon cables when removing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Luis Mena
メンバー登録日: 01/20/15
270 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-6, Blackwell Winter 2015 USF Tampa, Team 1-6, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S1G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 512
