はじめに
Throughout prolonged use of a cellphone, the top speaker will be prone to malfunctioning. Dirt and dust particles may enter the top speaker, which may in turn muffle or alter the sound playing from the speaker. If audio problems persist after you cleaned your device, the speaker may need to be replaced. This guide will show you how to replace the top speaker in your LG Stylo 3 Plus.
必要な工具と部品
Place the phone face down.
Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
Place the back cover off to the side.
Insert the opening tool into the small gap below the battery.
Carefully pop the battery out to prevent damage.
Remove the twelve 4mm screws using the Phillips #000 screwdriver.
Use the plastic opening tool to remove the inner case.
Carefully remove the inner case.
Gently flip open the flex cable box using a blue plastic opening tool.
Carefully remove the motherboard with your hands or a blue plastic opening tool.
