この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is the rear camera on your LG Stylo 3 Plus no longer taking great photos? Removing the rear camera for cleaning or replacement may sound daunting, but it only takes about 5 minutes and some simple tools. Follow this guide to quickly replace your rear camera and continue taking great pictures!
必要な工具と部品
Place the phone face down.
Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
Place the back cover off to the side.
Insert the opening tool into the small gap below the battery.
Carefully pop the battery out to prevent damage.
Remove the twelve 4mm screws using the Phillips #000 screwdriver.
Use the plastic opening tool to remove the inner case.
Carefully remove the inner case.
5 の人々がこのガイドを完成させました。
