メインコンテンツにスキップ
LG Stylo 3 Plus Battery Replacement
必要な工具と部品
  1. LG Stylo 3 Plus Battery Replacement, Back Cover: 手順 1、 3の画像 1 LG Stylo 3 Plus Battery Replacement, Back Cover: 手順 1、 3の画像 2 LG Stylo 3 Plus Battery Replacement, Back Cover: 手順 1、 3の画像 3
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Battery Replacement, Battery: 手順 2、 3の画像 1 LG Stylo 3 Plus Battery Replacement, Battery: 手順 2、 3の画像 2 LG Stylo 3 Plus Battery Replacement, Battery: 手順 2、 3の画像 3
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Patricia Pires Dias
メンバー登録日: 10/26/18
900 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G6, Peak Fall 2018 UMass Dartmouth, Team S2-G6, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S2G6
3 メンバー
15のガイドは作成済み
4 件のコメント
Thank you for your help. When I took the battery out one of the 4 gold prongs is dirty tried to clean with a toothbrush, do you have any ideas to clean it?
pmorin3887 - 返信
The gold prong in the phone where the battery is
pmorin3887 - 返信
my phone goes from fully charged to 0 in a few minutes, I took the battery out and seen it was a bit bubbled. I have so far bought 3 new batteries for my phone and every time when I turn it on I get invalid battery and it turns off I have left the battery out for a week to reset it but I still get the error when I turn it on… please somebody help
crystalbic - 返信
It is &&^&@@ up you just got to get a new one you know you got to live to die even man-made machines I'm sorry I hope you can find a way to get over it and move on
Deez Blaccnuts -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 21
今までの合計 3,876
