はじめに
This guide will assist you in the removal process of the LG Stylo 2 Plus mid-frame.
必要な工具と部品
To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
Firmly grasp the battery and remove from the phone.
もう少しです!
終わりに
