はじめに
If your LG Stylo 2 Plus is experiencing problems charging, not holding a charge for long, or will no longer turn on it might be time to replace is battery. Battery replacement on this device is a simple task, but you need to remember to gentle; the back is made of plastic and can break.
必要な工具と部品
To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
Firmly grasp the battery and remove from the phone.
Please dispose of the old battery properly by bringing it to a electronics recycling facility or calling the phone number on the back for more instructions.
