はじめに
If your LG Rumor Touch needs a camera lens replacement, these are instructions to safely remove the camera lens.
  1. Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. Gently pry the battery out of the phone with the spudger. Gently pry the battery out of the phone with the spudger.
    • Gently pry the battery out of the phone with the spudger.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Unscrew the 5 #1 5mm screws.
    • Unscrew the 5 #1 5mm screws.
  5. Lift the inner shell from the phone.
    • Lift the inner shell from the phone.
  6. Push the camera lens though its socket, from the inside out.
    • Push the camera lens though its socket, from the inside out.
まとめ
Andrew Hodges
メンバー登録日: 2014年01月14日
119 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-2, Forte Winter 2014 Cal Poly, Team 17-2, Forte Winter 2014人のメンバー
CPSU-FORTE-W14S17G2
5 メンバー
12のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 199
