この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If there are a lot of issues on the phone such as the blue screen, the screen not turning on, or the headphone jack not working properly, it may be the motherboard. Use this guide to replace the motherboard to fix the issues listed above.
必要な工具と部品
Use a plastic opening tool to seperate the back panel from the device.
Remove the back panel.
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
ある他の人がこのガイドを完成しました。
