メインコンテンツにスキップ
はじめに
If there are a lot of issues on the phone such as the blue screen, the screen not turning on, or the headphone jack not working properly, it may be the motherboard. Use this guide to replace the motherboard to fix the issues listed above.
パーツ
パーツは指定されていません。
  1. Use a plastic opening tool to seperate the back panel from the device. Remove the back panel.
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. Place your thumb along the bottom of the battery and pry upwards to remove.
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. Remove the eight Phillips #0 screws from the internal support frame. Remove the eight Phillips #0 screws from the internal support frame.
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. Using your hand, pick up the midframe to  separate it from the phone.
    • Using your hand, pick up the midframe to separate it from the phone.
    • If the midframe does not want to lift off, go back and repeat step 6.
  7. Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up. The screen connector is the part that has P5 written on it.
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. On the side with the screen connector, pull the two tabs away from the device.
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
終わりに
ある他の人がこのガイドを完成しました。
Erika Heppner
メンバー登録日: 2018年02月21日
316 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team S4-G6, Thompson Spring 2018 University of North Texas, Team S4-G6, Thompson Spring 2018人のメンバー
UNT-THOMPSON-S18S4G6
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 175
